Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.39967
Test result value: 1.20097
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0.64514V Min: 0.64514V
Test result value: 0.64514V
PASS
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 500ms Min: 0ms
Test result value: 30ms
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.44969V Min: 0V
Test result value: 0V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.07946V Min: 0.44969V
Test result value: 0.88938V
PASS
MID:$02 TID:$81
Max: 0.64514V Min: 0V
Test result value: 0.63538V
PASS
MID:$02 TID:$82
Max: 1.07946V Min: 0.64514V
Test result value: 0.6549V
PASS
MID:$02 TID:$83
Max: 0.20142V Min: 0V
Test result value: 0.18056V
PASS
MID:$02 TID:$86
Max: 5,500ms Min: 0ms
Test result value: 1,400ms
PASS
MID:$05 TID:$83
- O2 Bank 2 Sensor 1
Test result value: 1.08775
PASS
MID:$06 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 2 Sensor 2
Max: 500ms Min: 0ms
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Test result value: 0.89938V
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
Test result value: 0.16494V
PASS
MID:$06 TID:$86
Test result value: 1,370ms
PASS
MID:$21 TID:$84
- Catalyst Monitor Bank 1
Max: 65,535 Min: 4,096
Test result value: 4,369
PASS
MID:$22 TID:$84
- Catalyst Monitor Bank 2
Test result value: 4,343
PASS
MID:$22 TID:$85
Test incomplete or dependant test failed
MID:$3b TID:$81
- EVAP Monitor (0.090")
Max: 65,535 Min: 3,043
Test result value: 3,044
PASS
MID:$3c TID:$81
- EVAP Monitor (0.040")
MID:$3d TID:$81
- EVAP Monitor (0.020")
MID:$3d TID:$84
Max: 127.99609mA Min: 0.59766mA
Test result value: 0.79688mA
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,239.90002°C Min: 759.90002°C
Test result value: 820.10004°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 2,178Ohm Min: 0Ohm
Test result value: 110Ohm
PASS
MID:$45 TID:$85
- O2 Heater Monitor Bank 2 - Sensor 1
Test result value: 819.79999°C
PASS
MID:$46 TID:$81
- O2 Heater Monitor Bank 2 - Sensor 2
Max: 2,640Ohm Min: 0Ohm
Test result value: 120Ohm
PASS
MID:$81 TID:$4a
- Fuel System Monitor Bank 1
Max: -2,449.19995 Min: 2,667.19995
Test result value: 1,049.59998
FAIL
End of report.
MID:$01 TID:$83
PASS
MID:$02 TID:$01
PASS
MID:$02 TID:$02
PASS
MID:$02 TID:$05
Max: 500ms Min: 0ms
PASS
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
PASS
MID:$02 TID:$83
PASS
MID:$02 TID:$86
PASS
MID:$05 TID:$83
PASS
MID:$06 TID:$01
PASS
MID:$06 TID:$02
PASS
MID:$06 TID:$05
Max: 500ms Min: 0ms
PASS
MID:$06 TID:$07
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$06 TID:$86
PASS
MID:$21 TID:$84
PASS
MID:$22 TID:$84
PASS
MID:$22 TID:$85
MID:$3b TID:$81
PASS
MID:$3c TID:$81
MID:$3d TID:$81
MID:$3d TID:$84
PASS
MID:$41 TID:$85
PASS
MID:$42 TID:$81
PASS
MID:$45 TID:$85
PASS
MID:$46 TID:$81
PASS
MID:$81 TID:$4a
FAIL
End of report.
