Looking for some insight/input... have a 2011 x5 e70 35d - currently 490000 km on it (just over 300000 miles), original tranny.
I baby the thing usually, gentle accelerations, or decelerations.. never had any tranny issues before.
While driving it a month ago, for the first time ever I got the transmission error pop up on the dash... felt like it slipped.
Was driving at about 80km/hr when it redlined and went into limp mode.
I'm no mechanic but I did do A LOT of work on this damn truck over the years. Good old youtube and elbow grease. Figured this was next on the list.
Tranny was never worked on, fluid never changed (Didn't even know you're supposed to until this happened).
So I dropped the pan, pulled the mechatronic seals/sleeves, replaced it all. Oil was very dark and smelled burnt. The 2 magnets in the pan had thick toothpaste-consistency layers on top.
I got out 2 full washerfluid jugs of oil (3.78L each) so close to 8L.
Pentosin ATF-1 went back in. Got 5L in. Ran it til warm. got 1 more liter in before it started to over flow. So I managed to get 6L in. Could not fit any more.
It drove fine the 1st couple of days.
Then I started having weird issues.
1st stars off fine from stop, but then it jerks a bit when shifting into 2nd. 2nd to 3rd is same. 4th into 5th is super weird. It revs up to 5000rpms, then jerks it forward hard.
6th is the only one that feels normal.
Today going up a gentle hill and increasing speed from 70km/hr to 80km/hr, it dropped the rpms again to 5000, then lost all power, and went into the tranny limp mode.
I pulled over, turned engine off, back on and the error went away.
I feel like it's starting to happen more, and shift harder the more time passes since the oil change.
It has been about 2 weeks now.
Any suggestions? I can't really afford a new car/nor a new tranny.... so any input as to what can be done from here in order to lessen the issues at the least.
I still have about 4L of Pentosin left. Would another oil change in about a month or so help? Wouldn't drop the pan, maybe just do another drain and fill.
I'd probably need one more liter I'm thinking...
