BMWFS 2005 Lease Programs - Effective 3/3/2005
Add 2% to Residual Value for 12k mi/yr and 3% for 10k mi/yr on all terms
325i Sedan
24 mo/15k mi - 65% Residual Value - Money Factor .00225 Base Rate
36 mo/15k mi - 55% Residual Value - Money Factor .00225 Base Rate
48 mo/15k mi - 44% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 36% Residual Value - Money Factor .00255 Base Rate
325Xi Sedan
24 mo/15k mi - 65% Residual Value - Money Factor .00200 Base Rate
36 mo/15k mi - 55% Residual Value - Money Factor .00200 Base Rate
48 mo/15k mi - 43% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 35% Residual Value - Money Factor .00255 Base Rate
325i Coupe
24 mo/15k mi - 62% Residual Value - Money Factor .00100 Base Rate
36 mo/15k mi - 57% Residual Value - Money Factor .00100 Base Rate
48 mo/15k mi - 41% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 33% Residual Value - Money Factor .00255 Base Rate
325i Convertible
24 mo/15k mi - 70% Residual Value - Money Factor .00150 Base Rate
36 mo/15k mi - 60% Residual Value - Money Factor .00150 Base Rate
48 mo/15k mi - 47% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 39% Residual Value - Money Factor .00255 Base Rate
325iT Wagon
24 mo/15k mi - 61% Residual Value - Money Factor .00100 Base Rate
36 mo/15k mi - 53% Residual Value - Money Factor .00100 Base Rate
325xiT Wagon
24 mo/15k mi - 61% Residual Value - Money Factor .00125 Base Rate
36 mo/15k mi - 53% Residual Value - Money Factor .00125 Base Rate
48 mo/15k mi - 42% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 34% Residual Value - Money Factor .00255 Base Rate
330i Sedan
24 mo/15k mi - 61% Residual Value - Money Factor .00225 Base Rate
36 mo/15k mi - 52% Residual Value - Money Factor .00225 Base Rate
330xi Sedan
24 mo/15k mi - 62% Residual Value - Money Factor .00210 Base Rate
36 mo/15k mi - 53% Residual Value - Money Factor .00210 Base Rate
330i Coupe
24 mo/15k mi - 62% Residual Value - Money Factor .00080 Base Rate
36 mo/15k mi - 57% Residual Value - Money Factor .00080 Base Rate
60 mo/15k mi - 34% Residual Value - Money Factor .00250 Base Rate
330i Convertible
36 mo/15k mi - 61% Residual Value - Money Factor .00150 Base Rate
48 mo/15k mi - 48% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 40% Residual Value - Money Factor .00255 Base Rate
M3 Coupe
24 mo/15k mi - 67% Residual Value - Money Factor .00200 Base Rate
36 mo/15k mi - 58% Residual Value - Money Factor .00200 Base Rate
48 mo/15k mi - 49% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 41% Residual Value - Money Factor .00255 Base Rate
M3 Convertible
36 mo/15k mi - 59% Residual Value - Money Factor .00200 Base Rate
60 mo/15k mi - 42% Residual Value - Money Factor .00255 Base Rate
525i Sedan
24 mo/15k mi - 71% Residual Value - Money Factor .00125 Base Rate
36 mo/15k mi - 60% Residual Value - Money Factor .00125 Base Rate
530i Sedan
24 mo/15k mi - 69% Residual Value - Money Factor .00125 Base Rate
545i Sedan
24 mo/15k mi - 68% Residual Value - Money Factor .00100 Base Rate
36 mo/15k mi - 59% Residual Value - Money Factor .00100 Base Rate
645i Coupe
24 mo/15k mi - 67% Residual Value - Money Factor .00255 Base Rate
36 mo/15k mi - 56% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 38% Residual Value - Money Factor .00255 Base Rate
645i Convertible
24 mo/15k mi - 66% Residual Value - Money Factor .00255 Base Rate
745i Sedan
24 mo/15k mi - 67% Residual Value - Money Factor .00125 Base Rate
36 mo/15k mi - 58% Residual Value - Money Factor .00125 Base Rate
48 mo/15k mi - 40% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 31% Residual Value - Money Factor .00255 Base Rate
745Li Sedan
60 mo/15k mi - 32% Residual Value - Money Factor .00255 Base Rate
760Li Sedan
24 mo/15k mi - 57% Residual Value - Money Factor .00255 Base Rate
36 mo/15k mi - 50% Residual Value - Money Factor .00255 Base Rate
48 mo/15k mi - 35% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 28% Residual Value - Money Factor .00255 Base Rate
Z4 2.5i
24 mo/15k mi - 63% Residual Value - Money Factor .00200 Base Rate
36 mo/15k mi - 56% Residual Value - Money Factor .00200 Base Rate
Z4 3.0i
48 mo/15k mi - 38% Residual Value - Money Factor .00255 Base Rate
X3 2.5i
24 mo/15k mi - 66% Residual Value - Money Factor .00160 Base Rate
36 mo/15k mi - 57% Residual Value - Money Factor .00160 Base Rate
X3 3.0i
24 mo/15k mi - 67% Residual Value - Money Factor .00100 Base Rate
48 mo/15k mi - 46% Residual Value - Money Factor .00255 Base Rate
60 mo/15k mi - 37% Residual Value - Money Factor .00255 Base Rate
X5 3.0i
24 mo/15k mi - 64% Residual Value - Money Factor .00125 Base Rate
X5 4.4i
X5 4.8is
24 mo/15k mi - 61% Residual Value - Money Factor .00255 Base Rate
36 mo/15k mi - 53% Residual Value - Money Factor .00255 Base Rate
Remember, the dealer does not have to give you the base rate.
It is always best to compare other sources.
You can do this through
LeaseCompare.com.
Note: Regional rates may vary.
-Tarry Shebesta, OCLC
Certified Lease Consultant
