The TIS procedure uses ISTA Service Function to direct the process and cycle the appropriate DSC valves. It first drains the brake fluid tank. It notes the sequence of opening the two valves on each caliper.
BMW G12 M760Li xDrive Sedan / Repair Manuals and Technical Data / 34 Brakes / 34 00 Braking, check, ventilation / 34 00 027. Replacing fluid in brake system
You have a #120k car. Have the dealer do the $200 service. It may be covered by the 3y/36k maintenance agreement.
BMW Maintenance Program – BMW USA
Discover the items and services covered by the BMW Maintenance Program for qualifying BMWs.www.bmwusa.com
Doug Huffmand and Jaye944, thanks for the help and information. Sounds like the brake fluid change is going to be more complex than something I'd like to try.
Kssod, thanks for the hint on the BMW Maintenance program. It looks like brake fluid is covered in the maintenance program. I bought my car used but it's been less than 3 years and 36k miles so hopefully I'm covered. I did buy it from a BMW dealer. My car needs to get a PA state inspection here shortly. It's scheduled for early February at the local BMW dealer. I'll ask about the brake fluid change at that time. Hopefully the fact that I didn't buy the car from him doesn't present a problem.
Again, thanks everyone for the help.
