So, I've been fighting a shudder/vibration at highway speeds for some time now. Have had the tires re-balanced 3X, CABs replaced and suspension inspected...nothing!
Today, I took her out for a "spirited" drive and applied the bakes aggressively at high speed. . WHile I had thought the brakes were a little "rough" feeling, after a 20 minute session, the brakes literally were "grinding" under heavy braking and there was definitely a shudder in the front, felt through the wheel and floor boards when applying moderate to hard braking force. THe grinding and shudder began at speeds that seem to correspond with the vibration I have been getting.
When the brakes were hot and I applied force at higher speeds, it almost sounded like a semi truck with it's jake brake on!! WTF?!!!
Pads and rotors were all replaced 6k miles ago. Zimmerman rotors, Textar pads.
I have had the brakes apart and can push the pistons in by hand. The pins wer polished only a few weeks ago (I did not lube them).
Pads and rotors all appear to be wearing smoothly and evenly.
So...what could be causing this?
Thanks guys
