Brake light fuse
1 reading
5.3K views 11 replies 4 participants last post by  wrivera0783
#1 ·
Does anyone know what fuse is the brake light fuse on a 328xi? Nothing in the fuse box diagram shows which on it is. Search different boards but nothing.
#3 ·
They stay on all the time. I unplugged the brake light switch but they stayed so i figure its the fuse. But I can’t find the right one.
#5 ·
Sounds like a wiring problem, check the wire loom. Look for any cracked or open insulation. As the loom passes from the trunk lid over the hinges would be a good place to start.
#10 ·
Right you are. Go figure. I replaced the old brake light switch thinking that it was the solution to another issue. It wasn’t. It was the starter. (No crank no start) So, I put in the old switch and bam. The new switch was bad.
Thanks to everyone that tried to help.
You have insufficient privileges to reply here.
