1 - 6 of 6 Posts
just bought a 96 318ti cause gas is just killin me. only problem is brake like do not work and the brake pedal does not disengage the the cruise control(found out that bit of info the hard way:jawdrop::jawdrop::jawdrop:
brake pedal switch..tip: must break red tip to remove..use pliers..use eye protection unless you like trash falling in your eyes as you work upside down under dash.
its actually possible, though really hard, to remove the break light switch without breaking the red tip... it took me nearly 30 minutes just to get the old one out... :D you just have to pull it really hard, and it helps if someone else is there to move the break pedal around for you.
1 - 6 of 6 Posts
