03 330ci...recently purchased. Seller informed me of this problem, he said its an indication only problem however I want to ask the pros.
The yellow brake light comes on randomly and also a yellow triangle with a circle around it...seller said he's had it checked out, the fluid level is fine, the brake pads and associated are fine as well. He said he changed some sort of a switch or something on the res. cap I think.
He said when it comes on, if you stop, turn off car then turn on, light goes out and its does.
I find it annoying for one, and for another I'm not sure if it really is the start of a legit problem...btw, great forum. :beerchug:
