1 - 5 of 5 Posts
Hello Guys:hi:,
I have a 1995 Bmw 325is coupe (E36) and i'm having a minor problem with my brake lights:confused:, The check control say's that i have a" Brake light circuit" and "Brake light fail":dunno:. My owners manual says to replace a defective bulb, fuse or circuit defective:eek:, Has anyone else ever had this problem? Is there anything other than replacing a "Brake light bulb" i should diagnose to hopefully solve my problem...Thank's:)
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
"Brake light circuit" is probably your brake switch failing. It's located above the brake pedal.
BMWCCA HPDE Instructor
Brake circuit failure = faulty brake pedal switch.
Bulb out warning = brake light bulb out.
Sounds like you need a new brake pedal switch, which is about $30, and is pretty easy to replace. This is a fairly common failure item.
1 - 5 of 5 Posts
