I am about to work on my wifes bmw 325i for the first time. I will replacing brake pads, and trying to address the issue we're having with front end vibration.
Should I replace the brake pad sensors as well as the pads? And what brand do you guys prefer?
Theres alot of play in the front wheels when the vehicle is lifted off the ground which makes me suspect bushings and stabilizer or sway bar links. I need help with part brands recommendations, as I stated this will be the first time I've replaced any parts on the car and I know alot of you will have had more experience and knowledge about particular brands.
Has anyone heard of Beck/Arnley? Has anyone used the E46 Control arms and Tie rod kit from FCP Groton? I used them alot for my volvos for years and was satisfied but these parts are from different manufactures and I wanted some more input before I started buying parts. Thanks alot
