1 - 14 of 14 Posts
Normally I’d hate to make multiple posts within a few hours but this is quite bad. So I’m following my friend and he stops quickly at a light. I press the brakes and very weak brakes. I press them all the way to the floor, the abs goes off and I finally stop( thank God). The brakes will stop the car but the pedal will slowly go right to the floor. I have a month old pads and rotors in the front. I’m thinking it might be the master cylinder but I’m not sure
That's my guess.
2001 BMW E39 540i Automatic Sedan, 192 K miles
Your brake fluid may be low -if so, bleed and refill it to the max mark.
Or your master cylinder may be failing.
Low fluid should trigger the warning. There's a level float in the reservoir cap.
Discussion Starter #5 (Edited)
Found the problem:
It’s the brake line closest to the engine block
Fluid shoots out every time the break gets pressed.
Luckily I’m in a really good area so I’m going to come back tomorrow morning with a tow truck.
The leaky brake line hole looks pretty small.
I'd tightly cover that hole with a tape. Then, I would buy a quart of brake fluid (Pentosin dot-4), use to fill up the brake reservoir, and slowly drive the car to the mechanics garage. Stop and refill when necessary.
That is probably cheaper than the cost of a tow truck...
No you don't!!! You have a ruptured brake line. Do not gamble with anyone's life by driving it on the road. Please...
Discussion Starter #8
Luckily with liberty Mutual’s roadside assistance that costs 9 dollars a year, a towing is covered for us
Discussion Starter #9
2 new brake hoses and 100 dollars later... I am back on the road..... for now.
Member Supremo
That. Is very bad info.
OT: I take it you had a mechanic do the job? It would need a diagnostic system bleed after a ruptured ABS line.
I replaced my brake lines with the ECSTuning set and like the upgrade.. the ones under the hood do fail..
So, my question to you is whether you have replaced the other brake hoses on the 4 corners? If this is any indication, the other brake hoses won't be too far behind.
Discussion Starter #14
My 2 front ones were replaced a few months ago.
Owning a BMW is always interesting
1 - 14 of 14 Posts
