I would think that as long as the rotors meet the minimum specifications for thickness the most they would do is resurface them. If there is no pulsation they might just leave them alone.
My car shows service due for front brake pads and brake fluid change. I was shopping around for the brake job quotes and it ranges from $750 to $800 for front brake pads and rotors (pads and rotors inclusive) replacement - $90 for each pad, $160 for each rotor and the rest is labor charges - which is $200. These don't include brake fluid change - brake flush is $70-$100 ($70 at a shop and $100 at the dealership).
I found a few good DIY videos on how to replace brake pads and rotors. I am planning to replace the brake pads, sensors and rotors myself. I have a few questions before I begin:
1) Are there any precautions that I need to take or anything that I need to be aware of?
2) Do I need to purchase rotors or pads of a specific manufacturer or can I purchase a good set at the nearest Autozone or any auto shop?
3) I found a ceramic pads for $90 a set. What is the difference b/w ceramic and regular pads?
4) I know pads and rotor replacment are pretty much mechanical and technical involvement. How about brake fluid change? Is brake flush required? And for 2008 X5 3.0Si how much oil and what type of oil do I need to buy?
Thank you in advance for sharing your valuable experience.
I was "palpating" the rotor and noticed a slight rise towards the edge of the rotor. I ca't say the rise is significantly high but it is not unnoticible. That means the brake area of it was worn out. When I bought the car it had 52K miles on it. I put on 2K on top. Does that mean the previous owner never changed the rotor and now it needs replacement? I know it requires quite a few examinations before making a virdict.
... Are there any precautions that I need to take or anything that I need to be aware of?
