2007 E93
So I'm hearing a squeal in my drivers side front when i'm turning the wheel and braking when parking. So I assume its the pad sensor telling me I need new pads. I've replaced brake pads before on other cars, so I want to do them myself. what I'm not clear on is:
1. With 52,000 miles, do I need new rotors too? They feel smooth.
2. There is way to many brake pads to choose from. I want the same if not better braking power that I have now. I dont like the all brake dust but I want the same performance. any suggestions?
if your pads are worn to the point where you are hearing a squeal ( often caused by metal backing of pad contacting metal rotor), it is curious that you are not getting a brake pad replacement light on the dash. As to new pads, I put HAWK HPS (High Performance Street) on my E39 and was very satisfied.
Note: Don’t forget to replace brake pad wear sensors.
