1 - 10 of 10 Posts
· Registered
So a few months ago I was adjusting the rearview mirror of my 2001 530i and accidentally pulled too hard and broke it off. I taped it back on, been driving it like this ever since. It looks bad and also the tape never sticks fully, it's still loose.
Wondering if there's a way to repair it short of having a whole new windshield installed?
The metal piece that attaches onto the glass, it ripped some of the glass away with it. I tried to glue it back into place using 3000 lb. epoxy, but for whatever reason it didn't hold at all, it fell off again after I let it set according to the directions (I even cleaned it with solvent first).
Or will I have to get a whole new windshield?? Has this happened to anyone else reading this?
· Registered
The reason it doesn't hold when you glue it could be because of the profile of the surface inside the broken area, so maybe it can't bond correctly.
You'll have much more chances of making this work if you use dedicated rearview mirror adhesive kits (Loctite and Permatex make them), or maybe 3M VHB tabe (the one used for camera mounts and such). A dashcam camera mount glued to the windshield usually breaks the windshield if you try to force it out - you have to use cutting wire to get it off safely.
In all cases, if your epoxy spread all over the place you might have to clean it first.
Can't hurt to give a call to 3M too, they should be able to point you to the correct product.
· Registered
Did u try to use the special mirror glue?
· Registered
Discussion Starter · #4 ·
Both surfaces are rough and jagged glass, so I'd think that would help it bond better than if it were smooth. I really don't get why it didn't work. Idk if I'd have better luck with a different brand adhesive. I guess it can't hurt to try again.
· Registered
A lot of insurance co's replace windshields for free if you tell them it's cracked more than a few inch's.
Had them replaced on both the 528i & Chevy truck for free....just day's apart.
The BMW was a water leak at the roof, but told them it was cracked by road rock.
· Premium Member
I'd just use your insurance and get a new one
1 - 10 of 10 Posts
