1 - 5 of 5 Posts
Hit something on the road and cracked the plastic piece by the fog light. What’s the actual name for the plastic part? Do they sell this piece as a whole ? If so, where ? Anything helps. I’ve attached some photos. Thanks I’m advance.
Use RealOem.com, enter your VIN. You should be able to locate the part number.
Once you have the part number, do an Intrernet search for it by putting BMW and the part number.
It's probably #7 in the diagram here - http://www.realoem.com/bmw/enUS/showparts?id=3B53-USA-12-2014-F30-BMW-328iX&diagId=51_8505
It's the right one so ends in an even number. Part # 51-11-7-300-740. If you pull your broken one off you'll probably see the part number on the back somewhere to confirm.
As mentioned above, put your VIN into the start page at realoem & it'll take you more specifically to your model.
You can find the factory repair manual here - https://www.newtis.info/tisv2/a/en/
It's a fast and simple repair. I've had to do mine once.
When you get the new part you will see where the clips are located and you can just reach into the broken one to release them. Then just pull the old one out and push in the new one.
1 - 5 of 5 Posts
