It's valve seals. It always is on the N62 engine
BMW Level 1 Master Tech
2006 E60 M5
2006 E60 525i
2001 E39 540i (for sale)
2006 E60 M5
2006 E60 525i
There is an updated valve stem seal that eliminates the cavity that forms as the seal wears. This cavity allows the oil to pool at the top of the valve guide. In my mind, this makes perfect sense and will have to see over time if the problem resurfaces without changing guides.Thanks guys..
Doing the seals only, will buy ya a couple years.. then it will start to come back.
Thanks again.
So if you think about it you're doing 2 things;Performed the procedure as per the link that A B Able Truck mentioned..
So we played with by buddies car today...
Pulled all 4 connections off the Vanos solenoids. Went for a drive and then parked it facing down hill... Let her idle for about 10 mins. Gave the throttle a punch..There was a little bit of blue smoke. Not the massive cloud of blue /white like yesterday... Much less!!!
We then drove around some more, and tested it again... and again some smoke.. but less the first time... nice...
We are gonna leave it this way until next weekend to see if the smoke all but disappears.
It's definitely better, right out of the gate
Car drives well... Idle is around 700 RPM vs. the 500 RPM it is usually idles at. And the engine light is on because of the 4 codes in memory.
I will update as we go....
Thanks.
$40 & 1 hour labor - works great (CCV hose configurations vary)I was thinking of getting an oil catch can for my car... as I do see oil residue in that connector leading into the intake from the valve covers...
if CCV's are working as they should, there should be very little oil and gasses getting into the intake anyways I would think?
1st time i had the same thinking as you, but i check a lot of bmw even the brand new one still the same. => bmw pcv is junk... But when car new they didnt burn oil.I was thinking of getting an oil catch can for my car... as I do see oil residue in that connector leading into the intake from the valve covers...
