1 - 9 of 9 Posts
Bavarian Garage
Noticed a bulge on the interior of my passenger rear tire on my Z4. Same set-up as my E92 except they're non-RFTs. 225-40-18 (R) and 255-35-18 (F). If I order a new rear tire from Tire Rack and specify the size, will the one I receive be the right width? I'm assuming the tires are 8.5 on the rear and 8 on the front. Do I have to specify the width or will the size denote the right width? Maybe I'll just swap the RFTs from the E92 to the Z and get non RFTs for the E as it's my daily driver. Either way, I've got the same issue.
E92 Fanatic
You got your tire backwards, it should be
Front = 225/40/18
Rear = 255/35/18
Your rear wheels are wider than the front (225) and therefore need a wider tire (255)
Bavarian Garage
Discussion Starter · #3 ·
you're right TL, got it reversed. So, do you know the answer to the question? Will ordering a replacement tire come in the correct width?
Flying monkey herder
the tire size denotes the width.
255= tire width, in mm
35= aspect ratio, tire width to sidewall height, percentage
18= rim size, in inches
E92 Fanatic
yep, as long as you tell them which tire you're replacing, the front or rear
Drive it like u stole it!
Dont drive the car until you have it replaced. You can have a blowout very easily and lose control of the car.
How old are the tires? Maybe you can get it replaced under the manufacturer's warrantee.
What about the tread depth difference on the axle? If one is 50% worn, will it make a difference to have the other 2/8's inch higher?
1 - 9 of 9 Posts
