1 - 6 of 6 Posts
Hi.
My BMW is from 08/2010 year.
I bought harness for rear camera, camera and module.
I connect corretly based on newtis.info.
1 pin - +12 V
2 pin - 18 pin CIC
3 pin - 28 pin CIC
4 pin - 27 pin CIC
5 pin - CAN
6 pin - CAN
7 pin -EARTH
I codded it corretly via e-sys.
When i engaged reverse gear, in CID i see rear view camera but image was green.
So, today i checked harness and its OK.
I checked also camera and module by install my camera and module in other car.
Once module, once camera, once camera and module together. It allways work very well.
But not in my car.
<a href="https://ibb.co/3WxT8Qf"><img src="https://i.ibb.co/y5zNM7h/IMG-20190209-213752.jpg" alt="IMG-20190209-213752" border="0"></a><br /><a target='_blank' href='https://aluminumsulfate.net/aluminum-oxide'>chemical name al2o3</a><br />
If you vo codded all the required modules, you need to open ista+ >service fuctions>driver assistance>all round vision camera> learn/calibrate reverse camera.
Discussion Starter #3
I calibrate rear view camera in insta and no success.
When i put my camera and module, or only camera or only module in another car (plug and play) it works OK.
Discussion Starter #4
Theres a one error in HU_CIC module.
b7F841 CIC: CVBS input 1, novideo or sync signal
But... cables connected properly
Discussion Starter #5
i coded once again hu_cic and trvsc module and no success.
Cables connected properly but theres a error in insta. :(
I connect it with shorter cable and some higher quality cable and no success.
Discussion Starter #6
OK.
I dont know why,but settings for RVC_CIC etc. should be werte_21.
On tool similar to ncs dummy (i dont remember the name) were bad information.
When i code (to default settings via code button in esys) settings changed to werte_41 too.
1 - 6 of 6 Posts
