I have a 7 seat F46. I see that there is not a section for this particular 2 series, but here's hoping that someone can explain a potential issue with the Can-bus.
I intend to fit a towbar to the car, and will be fitting aftermarket dedicated electrics. The control box is made by Jaeger and it only needs a few connections. The instructions for hooking up to the Can-bus show to connect to the multi connector high up in the wing next to the 3rd row of seats. But to reach that I would need to remove the trim card which requires removal of the 3rd row seats (and all the wiring to the seat belts).
There is another option to run the twisted pair to the front footwell and connect to the black 54 pin multi plug pins 49 and 50. But this requires removing plastic trim to reach, and I don't like removing trim in this cold weather as it can be brittle and crack.
However, the instructions state that if these 2 pins are already occupied then to crimp onto the twisted wires already connected to 49 and 50.
SO..... to the meaty part of this post.
In the boot there is a Can-bus pair which are going to a box on the rear panel. This could be the control for the tailgate, or the reversing camera - I don't know which. It would be so much simpler to crimp on to these as they are easily exposed. But I am wary of connecting to these as I don't know whether these are the main Can-bus that are the equivalent to those in the front footwell. Is there is a rear gateway, and is it that these wires are not the main Can-bus, i.e. is this just info from the boxes mounted on the rear panel and might therefore throw up some codes?
Can anyone experienced on Can-bus in BMW's shed any light on this please?
Many thanks
Jeff
Many thanks
Jeff
