1 - 17 of 17 Posts
i read this at a post on .org:
1. Finally, if you turn off the fan on the climate control and then turn off your car, it DOES NOT turn back on automatically when you start the car again. Hallelujah!
2. The steering wheel buttons now scroll through all sets of radio presets.
if that is true, then can dealers program 2001's climate control to stay shut off? thanks
Gone Motoring!
you can program all the ACC to stay shut off, just talk to Larry or Bart next time u'r there. I keep forgetting to get that done myself! I can give you the code later, I'm pretty sure it's in the Bentley manual.
--Andrew
Discussion Starter · #3 ·
Re: Re: can someone with a 2002 sedan confirm..
--Andrew
andrew -
i asked last time i was there. they said they didn't know what i was talking about. i even went in with the long car/key sheet that said the "auto blower" could be turned off. if you get the code let me know, cuz it's no bother to me to drive through temple to get to killeen when i go. haha, maybe if you dont hvae time to go we can trade cars for a weekend and i'll take it to gs on friday bring it back to you on sunday... ummmm 330 sweetness.. ;) :D
Not sure about the fan thing, but I think it does stay off.
The steering wheel buttons only scroll through one bank of presets at a time, though. Must hit the "FM" button on the head unit to change banks still.
The Original Dr. Phil
On my radio, scrolling with the steering wheel buttons will run through FM 1 then FM 2 then back to FM 1. You have to hit the FM button if you want to go to FM A (the auto scan and set stations based on signal strength).
As far as the fan, you are correct if you had turned it off prior to shutting car off then next time you start the car it is still off.
King of Rear Clunks
Hmm...
I have an 01 and the HVAC goes back to whatever it was set to when the car was shut off (I thought this was part of Car Memory too), but the presets do NOT go from FM1 to FM2 then back.
Kaz said:
Hmm...
It must be a change to 02 for the FM scrolling:dunno: Ichecked it over lunch to make sure I wasn't wrong and it definately went from 1 to 2 to 1.
Senior Slacker
Off is off
I always shut off my HVAC by pushing the fan button and it stays off when I next start the car. I believe the steering wheel controls do cycle through all of the fm presets but I will have to check that later. I do not recall telling the dealer on the car key memory form to program my HVAC but at my age you tend to forget these things. I have an '02 coupe.
Re: Off is off
vexed said:
....but at my age you tend to forget these things. I have an '02 coupe.
At least you remembered what kind of car you have;) I respect a man who can make light of himself:thumb:
Are you feeling the love today?
Senior Slacker
Re: Re: Off is off
Car...car, oh that car.:D Hey so far it is a real love fest except for that other thread that I am not touching.:eek:
What would be even better is if you could make the steering wheel buttons function like the seek buttons on the radio. I know you can do this by holding the button on the wheel for 1 second, but that's very annoying. If you press the M button on the radio, the buttons will scroll through each station. For some reason, BMW makes it hard to do the most common thing- browsing the next available radio station from the steering wheel. Presets do no good if your always travelling between different areas and browsing through each station on the dia is also tedious.
It seems like there are a few simple, obvious improvements that BMW could make that they have resisted for years like:
1. headlights off w/ ignition. i know this now happens on 02 cars equipped w/ auto headlights. BUt this is a basic feature and shoudl be part of all their cars--note i'm just talking about the headlights shutting off w/ the ignition not auto headlights.
2. In-dash CD Changer. Other makes have had this for years- including Fords and Hondas.
3. track time remaining display on CD player. Not so important but almost every other CD player has this basic feature.
4. DVD-based nav. GRanted this is a *little* more complicated but other manufacturers have had this for several years. Can't BMW just use different suppliers if their own suppliers can't make one?
Its wierd that BMW messes up on what should be the "no-brainer" stuff. Even the problems that BMW's tend to have fall into this category: thermostats, door seals, rattling seatbelts, engine fans, etc.. All basic things that have been around for over 50 years- and they manage to screw them up. They get the more complicated stuff right, but the can't seem to do the basic stuff. Very strange-- i just don't understand it. Its not like it even takes much engineering time to develop these things since they've all been done and perfected by other automakers and suppliers. Even GM and FOrd get this stuff right.
I double checked too, and mine definitely does not go through FM1 then FM2... perhaps this improvement was not made to the stereo with Nav.
Gone Motoring!
Re: Re: Re: can someone with a 2002 sedan confirm..
eugeneDC/TX said:
andrew -
we'll dig through the Bentley manual this Friday afternoon and find out! =)
--Andrew
King of Rear Clunks
1. My headlights shut off when I turn the car off. Parking lights stay one, though.
2. I agree, though that would require a 1.5 or 2x DIN radio, and BMW seems to like using regular 1-DIN to sorta fit with the trim strip (except for NAV of course)
3. Or ANY time display, for that matter. A friend of mine recently put a Kenwood 919 in his Camry, and I really liked the animated time display. Oh how I miss aftermarket radios...
4. They offer this in Japan already, where a CD-based NAV will just get laughed at. It appears they use the same radio (MD is standard; cassette is no-cost) but use an Alpine-based DVD NAV computer and drive instead of the VDO-Dayton (?) CD one we get here.
That must be the case, good detective work Plaz:thumb:
I meant parking lights go off- not headlights. It makes no sense that the parking lights stay on after the ignitions is switched off. If you wanted them on you could turn the switch to the parking position, or you could put the blinker in the left or right position which will turn on the parking lights for that side of the car. It doesn't have anything to do w/ german law either other eurpoean cars shut off all their lights w/ the ignition.
Sorry, for some reason this one pisses me off. I guess because I had an 87 Volvo that did this and my 2001 BMW can't.
1 - 17 of 17 Posts
