1 - 6 of 6 Posts
Hi, new to the forum. I am looking at a 2005 Z4. Can the roof pump be inspected visually without disassembling anything or removing the top? Look for water stains? I don't see any seal I could move back and look down in there.
I was thinking I could poke the drains from the bottom but not water would only tell me half the story. I want to see if there are any signs the pocket filled up with water and flooded the motor/pump assembly.
Thanks for any insight!
Its hard to see down there even if you know what you are looking for. Easiest way to check the drain plugs is pour a litre of water down each side, it should flow straight out under the sills in front of the back wheels.
Discussion Starter #3
Well hopefully the seller is ok with that! :)
If you push the bottom edge of the head liner back in the area just by the driver's shoulder you can see the pump housing if you use a flashlight. If the pump motor is really corroded there's sometimes some rust stains you can see. Note that you can have a perfectly clean looking motor housing and still have a severely corroded motor.
To be pedantic, the motor sits on the left of the car just in case you are UK based.
Discussion Starter #6
Thanks, let me give that a try.
1 - 6 of 6 Posts
