1 - 10 of 10 Posts
I have a 93 325 converted with a 95 m3 s52 engine. I replaced water pump, water pump pulley, belt tensioner, idler pulley, thermostat and it's housing. I also replaced tensioner and belt on compressor. That belt went on fine. I can't seem to get this one on. I got belt and tensioner at BMW. I think the belt route and the actual belt are the same for both 325 and m3. It seems this belt is about an inch too small. What am I missing here?
The belt part is #6k-1555. I also went to advance and the belt they had was the exact same size, so I think I got the right one, not sure.
Any advice greatly appreciated.
Discussion Starter · #3 ·
Sorry for leaving out some info. I have the manuals, I have replaced many belts in the past, and I have been using a torx bit to relieve all of the tension on the tensioner puller. Still seems short. I have been searching online for hours to no avail. Has anybody out there had a similar problem?
BMWCCA HPDE Instructor
Torx bit? The A/C belt uses an 8mm hex wrench, and the accessory belt uses a socket (can't remember exact size) to release the tensioner. I don't know why you're having trouble though. I just replaced the belts on my 328 a few days ago and didn't have any trouble. Sure you have the right size?
RealOEM shows the same belt for both your original engine and your transplant M3. Both belts are 1555mm. I just replaced my belts and I wound up slipping the belt over the tensioner pulley last since it doesn't have a shoulder on it. That was the easiest way to get it on. Also you need to make certain the belt is seated in the V grooves in all of the other pulleys. If it's not it takes up quite a bit of the length of the belt.
Discussion Starter · #6 ·
Finally got it on
My tensioner was somehow stuck open, it would barely move. I stripped the bolt and my tool trying to get it to move more. I could move it a bit, but after I installed a new one it torqued much more and I was able to easily slip the belt on. Funny I thought a tensioner would fail and then not spring out anymore, but it's fixed now. Thanks for all your suggestions.
Discussion Starter · #8 ·
My tensioner pulleys required a Torx bit, T47. Even got a new one from the dealer, same "star" pattern. Different from others here, obviously, but definitely not a hex bit or a socket. It was the idler pulley that required a socket.
This is interesting, because it looks like we're slowly discovering that BMW had three different designs for the tensioners. As I mentioned before, my car required an 8mm hex for the A/C belt, and a 16mm socket for the accessory belt tensioner. I consulted the Bentley manual before doing the work, and it made no mention of using a socket. I guess the Bentley PDF that I have must predate my car. So it seems as though, depending on the year of the car, the belt tensioners required either a torx driver, hex (allen) wrench, or socket.
1 - 10 of 10 Posts
