1 - 8 of 8 Posts
My car when in drive is squeeling liker mad. Sounds like a belt but isnt. It stops if a little gas is pressed. THe car seems to hesitate on take off. Im out of warranty just now. I have 92K miles on her. Please help.
i had squealing symptoms similar to yours a few months back and then got the low coolant message as well. turned out to be water pump.
Master Tinkerer
+1, likely the bearings on a pulley (water pump included). You should be able to pop the belts off and spin / wiggle each pulley by hand to tell which is noisy / wobbly. Could also be a little liquid on the belt (coolant / power steering fluid / oil).
Discussion Starter #5
So everyone would suggest I pull the belts off and see if something is wobbly etc?
What about the oil leak? do you think this is part of the problem or a separate issue?
760LI in HELL right now:(
sounds like the fan belt !?
The fan is electric and not belt driven. I could be a bearing. get an automotive stethoscope and listen to the bearings.
Master Tinkerer
Based on realoem.com's diagrams, the 760 / N73 looks like it still has a pulley-driven water pump and fan.
+1 on Judd's post, get stethoscope and listen or pull belts off and just spin each pulley until you find a loud or wobbly one.
Oil leak? Where does the oil appear to be leaking from? Pictures?
Ahh, I missed the 760 part.
1 - 8 of 8 Posts
