1 - 3 of 3 Posts
97' 540i
Hi all,
My 540 was working fine, all I did was join the Rear fogs to the brake lights, simple soldering thing.. and I go to test the lights, and the car will not start, the key turns, but all I get is the airbag light, and radio. not sure if this has to do with the Rear fogs or not.
HELP!!
Thanks in advance :)
Apparently your soldering was not so simple. How did you know which were the fogs anyway? America cars don't come with them.
The first thing you should do is undo the bad wiring. Then see if it works. Assuming it does work, leave things be until you get some help.
Cheers,
Bill
97' 540i
Discussion Starter · #3 ·
All works fine now, I moved the steering wheel and started right up.. then Re-soldered the fogs back up,(disconnected them when the Prob happen'd) to the brakes, and all works great now. Brakes are Bright as hell...why did that happen?? is my Ign switch going???
Thanks you.... for all your help.. as always, where would I be with out bimmerfest.
http://www.bimmerfest.com/forums/images/smilies/aim-angel.gif
:angel:
1 - 3 of 3 Posts
