1 - 6 of 6 Posts
Just went to start the car this morning. Got like 3 clicking noises, dash lights all work, interior fan came on. The headlights did a flickering in time with the clicking noises...all internal lights work....HELP ME!!!! PLEASE......
The Biggest P0st Whore!!
Sounds like your battery does not have enough juice to start the car. Try jump starting or test/change the battery. You can have enough power to run the accesories but not enough to run the starter.
Discussion Starter · #4 ·
My radio does not come on and my temp sensor now reads -40. I have a feeling it may just be the battery...It's the cheaper thing to replace, so I will try that first. Thanks!!!
Try jump starting and when the car is running, measure the voltage of your battery. If it is less than 13.5 Volts, then you'll have to replace the alternator instead of the battery.
If you don't have a voltmeter, try Test Nro. 9 of your OBC
http://www.ideaphile.com/bmw/540-obc.html
Discussion Starter · #6 ·
Replaced the battery with one from AutoZone...Titanium:dunno: Started right up...thanks to everyone for suggesting the battery route first.
1 - 6 of 6 Posts
