Hi all,
I can't for the life of me find these error codes/fault codes anywhere. They are all produced from Carly. Below is an example of them:
Code:
Motor Control:
Engine / Motor
Throttle angle - intake manifold absolute pressure, Comparative pressure too low
Code: 101F01
ABS / DSC / Brake:
Dynamische Stabilitäts Control / DSC
ECU OK, no Fault Code
Heating / AC:
Air conditioning / Klimaanlage
ECU not present/no response from ECU
Immobilizer System:
Body Domain Controler
Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung
Systems:
Infotainment
All function blocks Registered most nodes
Code: E1C447
Monitoring circuit reset was triggered
Code: E1C440
Chassis:
Steering /Lenkung
Electronic damper / Elektronische Daempfer
Body:
Automatisches Front Steering
Rear Electronics Module / Elektronik Modul hinten
Relay glue or fuse failure or short circuit to ground Fh Bfh, relay closing No output
voltage
Code: 030181
Integrated Chassis Management Quer/Längsdynamik
With greater uncertainty direction Vx 2 M/S- Sbs function
Code: 480134
Other:
Advanced Crash and Safety Management (ACSM)
Central Gateway / zentrales Gateway
:Synchronization failed
Code: CD0487
Fuel pump / Kraftstoffpumpe
Getriebesteuerung /Transmission
Tire pressure control / Reifendruck Kontrolle
Telephone
Hifi Amplifier / Verstaerker
ABS + DSC
:Sine: internal supply voltage
Code: 801A4C
:Temperature sensor 1 failure
Code: 801A56
Gear switch / Gangschalter
Instrument cluster / Kombiinstrument
:System time is set back
Code: B7F668
Flexible Bus-Interface / Schnittstelle
Central Control / Zentrale Bedieneinheit
Driver seat /Sitz Fahrer Heck
