Caster issue
4261 Views 25 Replies 8 Participants Last post by  dc_wright
I recently replaced my '92 318i's lower control arm and bushings. After doing that I was able to trust more in the feel back in the steering wheel, having to use very little pressure or back pressure to hold a turn especially at near lock. Going over things in my head I realized that the picture in the Bentley had the bushing in the middle of the area for it on the control arm, however it was all the way on when I took off the old ones from my car. I did what the manual said and put the bushings where they were previously, however I believe that is the wrong place and some previous mechanic was short coming with his work. My Question is now how do I return it to where it belongs, what is the process for figuring out the placement of the bushing on the control arm. And being on a budget I don not want to hear to take it to BMW.
See less See more
21 - 26 of 26 Posts
Okay, took me a while to calm down and actually see things correctly.
So, we have one fixed point in space, the ball joint at the sub frame. the bushing is holding a point in the X and Y, and then must then therefore be at a specific spot along Z.
The setting the car down while the bushing and control arm are still lubricated is to get out all the stresses. So, would it be good to drive the car to exercise the suspension before the lubrication dries?
and exactly how is the bushing to be oriented, again with clarity? (still have yet to watch video, though it seems to be for an E46.)
Btw, thank you all for bearing with my ... I don't want to say stupidity, but that's currently the only thing that is coming to mind.
P.S. Can't wait to get this car back to health ... even on my shoestring of a budget.
The installation process for the E36 and E46 is identical. The only difference is the E36 control arm bushing mount area is round and the E46 has a hexagonal cross section. If you used the BMW recommended lube, the "drying" is to all intents done about 30 minutes after you've applied it. I suspect the bushings will find their correct location with a bit of driving regardless and the lube is more needed to get them positioned so you can bolt them to the car frame.
See less See more
Photos aren't really what's important here. We all know that you can't adjust the placement of the control arm bushing on the control arm. The bushing lollipops anchor to the chassis in a fixed location, and the control arms themselves are anchored in a fixed location by the ball-joints which are bolted to the sub-frame. You can't move the either the control arm or the bushing fore or aft, since they were not designed by BMW to be adjustable in any way. As mentioned in an earlier post, the only variable is how far into the lollipop you pressed the bushing. But even then, it's probably only going to vary by a matter of millimeters, which won't have a perceptible effect on handling. And there is no "orientation" for the non-M control arm bushings, since they are centered.
Basically we have a car here which has had what sounds like one of two control arms replaced (they should be replaced in pairs), both FCABs relaced, and (I think...) no alignment performed afterward. That is a perfect recipe for wonky handling. And then of course there is the possibility of other unrelated/coincidental factors. But if you removed centered FCABs from the car and then installed new centered FCABs, the bushings are not what is causing whatever symptoms you are experiencing.
If this car really has not been aligned after the work was performed, do that first before wasting any more time trying to figure out what's going on. Trying to troubleshoot a misaligned car is pointless.
This x100000000
See less See more
The orientation of the slots doesn't have any influence on caster, though.
Side question, what is the BMW recommended lube?
See less See more
If you mean the slots in the non-M FCAB, yes, it does make a difference:
"New bushings usually come separate from the wishbone brackets. Press the bushing into the bracket using a vise or an industrial press. Make sure the bushing is centered width-wise in the bracket when you have finished pressing it into the wishbone. Each bushing has a small arrow cast into the rubber that should line up with the corresponding dot on the outside of the wishbone bracket (inset photo)."
(from the Pelican Parts DIY)
Thank You. There was more to Pelican's article than I noticed with the quick skim.
The bushing I have extra do not have the arrow. However there is enough of the bushing visible to properly orient the bushing if the bracket/wishbone has the dot.
I'm past the "caster" issue. I just want my car together correctly.
As I have read on here, BimmerForrums, and Pelican, The lubricant listed in the Bentley does not exist (or not anymore). However the solution I used, because I read about it on multiple posts, was dish soap. Though I do not know the dish soap's drying time.
See less See more
It's a kerosene based lube. The kerosene gives it a low initial viscosity and when the kerosene evaporates it leaves a very high viscosity compound that's almost adhesive like.
21 - 26 of 26 Posts
