Will catless downpipes fit the xi? Most websites I've been on say modification is required for the xi. Is this true?
It means it is not direct bolt on on the XI and will need some work before it fitsWhat does that mean "will require clearance?"
As far as I know AR no longer sells them.Clearancing on the VRSF means cutting one of the pipes and welding in a flat section to avoid contact.
The AR Design pipes are supposed to be direct bolt on, but are ridiculously expensive
N54tuning.comAs far as I know AR no longer sells them.
Wow thanks for that i did not know that thanks again. But again over $1,000!!!!!! Lol
