1 - 6 of 6 Posts
After used the radio code to get me radio to work after losing power from the battery my CD changer will not work. For some reason the option of CD is no longer available when selecting a source for audio. I use to have FM, AM and CD. Now I only have FM and AM on the in dash unit. Is their some way to reset the changer? What are my options?
2015 335 M-Sport Mineral Gray
Have you tried disconnecting the CD changer and then reconnecting it? This will cause the changer to get re-initialized and recognized by the radio. When you do this you will hear noises coming from your changer as it does a self-check.
ecool said:
I disconnected the CD changer in the trunk and reconnected it and still doesn't work. Anyone with any other suggestions?
Did your changer make any sounds when you reconnected it? It is possible it may not be getting power because of a blown fuse.
1 - 6 of 6 Posts
