07 - 330i - N54 - 77k miles
Trying to help a coworker out and change out the valve cover gasket. Found a lot of sludge when i got in there. Cleaned it out the best i could - put it all back together and it seemed ok until it dropped to warm idle. Check engine icon in the display comes up and the idle gets really shaky.
I replaced the PCV hose in the back of the head that always cracks and I thought it was good. restarted a couple times and the symptoms return.
USING ISTA - I get the following 2 codes
003100 DME: Boost pressure control, deactivation
002A82 DME: Vanos Intake
I have spent many hours going back over the job and cannot see where i forgot to connect something, or something else is cracked. I have inspected as must of the VC joint with a mirror and cannot see that it has rolled... When I pull the vacuum lines off the top accumulator bottles they release air.. so it seems they are holding a vacuum just fine
When i start it i know right away if im going to have the issue because I hear an on/off/on/off whooshing sound- like the tubo doing something.
Any ideas!!??
Any ideas!!??
