1 - 2 of 2 Posts
I just replaced my input camshaft sensor and expected the CEL to go away when I started the car. This did occurred on one of the sensors I already replaced that I couldn't remember the name. However, the CEL didn't go away. What gives?
By the way, the procedure was pretty easy. However the bolt that holds the sensor in place is a PITA to remove. It was just tedious and it was hard to put back on afterward.
Noone Special
clear the code with a code reader. Not all codes will turn off the cel once it is repaired. plus you have to perfomr the drive cycles to have the code checked three times before it will turn off
1 - 2 of 2 Posts
