1 - 6 of 6 Posts
Hi there,
Does anyone know where the central locking module is located? I know what it looks like, but I don't know where it is.
It's for a E34 1992, the auxiliary battery is under the back seat if that makes any difference.
Certifiable BMW Whackjob!
Auxiliary battery? Where is the main battery? What model do you have?
Is the module under the rear seat (opposite side from battery)?
Posted through Tapatalk downloaded to my neural implant
On E34's, the modules are located under the rear seat, opposite side as the battery. You can try "resetting"; disconnect power (remove Neg battery cable) remove both modules, check for any corrosion on plug side, reinstall & reconnect Neg battery cable. Also check all the fuses shown in the picture below. Sorry about the light color but that's the way the Bentley shows them.
1 - 6 of 6 Posts
