About a month ago I changed my 335xi 07 oil and when I unscrewed the filter housing it seemed under pressure and blew oil all over the housing and such. That's never happened before. I change my oil at 5,000 miles faithfully. Since then I started throwing camshaft codes and vanos codes. Not a single code was thrown before the oil change.
I read that the oil filter cage isn't in place properly it could cause pressure issues. Could it be related to the pressure I noticed when I opened the filter housing? Just odd it was fine before this happened?
I've replaced the cam sensors, vanos sensors are also replaced new. I have non return valves on order also to replace those.
The car purrs like a kitten and no rough idle or starts.
Still throwing vanos codes and cam codes. Today I threw a P0016 crankshaft - camshaft correlation code.
Ugh
any ideas before I take this to an actual shop. I'm looking to have it scanned by an actual shop with a BMW scanner system. I'm totally lost.
Ugh
