1 - 20 of 24 Posts
Coyote Racing Team
Open the trunk.
Take battery cover off of passenger side rear section.
Remove battery holder bracket.
Disconnect and remove vent hose and old battery.
Reverse steps for installation of new battery.
Coyote Racing Team
The tube or the part to connect to the tube should come with the replacement battery. I replaced mine last year with a Duralast from Autozone. I did not need a radio code or any electrical work to my car.
Keeping it surreal
The old battery is a vented-type....it`s possible the new one is a totally sealed, non-vented type....examine it closely to make sure. There should`nt be any electrical complications resulting from a battery change. Always hook up the Positive (+) cable *first*, then the Negative (-) cable.
Regards,
Bob
We want the Lion!
Regards,
Bob
Exactly. You may not think this is a big deal. IT IS. Why? If you connect the -ve cable first, then accidentally touch the body of the car with your wrench while tightening the +ve, you'll spot weld the wrench to whatever it touches. Or so I'm told :angel:. I now have a 1/2 inch and a 10mm wrench each dipped in about 10 coats of Plastidip that I use for changing batteries.
Discussion Starter · #11 ·
yes, thank you! I read my manual...it said to disconnect the negative cable first when removing the battery and CONNECT the positve cable first when putting the battery back in. But dipping the wrench in plastic is a good idea.
did you just melt down a bunch of plastic to do that?
konrad330xi said:
Same as J.Kidd. Just replaced a battery with a Duralast 49DL. No reset or electrical work was necessary other than resetting the clock. No problem with the radio.
Konrad, I noticed your garage is a 2004 325. Is this the vehicle that you had the battery replaced, and is your car still under warranty (i.e. less than 40K miles)? If so, shouldnt you have gotten a replacement OEM battery under warranty?
We want the Lion!
tiffany_w99 said:
now I'm having a very difficult time getting the bar off the top of the battery. the bolts are on so tight...
Squirt a bit of liquid wrench and let it sit for an hour. Worst case, try WD-40 - it's not really a penetrant, but might work.
Use a small socket if you have one :) .
You go girl (I presume the tiffany bit of tiffany_w99 == the fairer sex). :angel:
I'll have to check my garage. No, we replaced the battery in my wife's 2002 325xi, which is out of maintenance (we have an extended warranty). Battery replacement isn't covered.
But for $70, from what I've read, the Duralast is a pretty good investment.
Sorry, I meant your "mein auto." I ask b/c I had to have my battery replaced. However since my 325 only had about 3,200 at the time, BMW said it's not covered under warranty. Reason? The battery is dead b/c of lack of driving, so it's not covered. :(
We want the Lion!
Tiffany - It comes in a can, as a liquid. You just gently dip your tool in, then out, in, then out... Repeat as often as you like. :bigpimp:
1 - 20 of 24 Posts
