1 - 14 of 14 Posts
Any advice on why my check engine light isn't coming on when I turn power on? Trying g to pass inspection and the guy reset computer. Drove it 100+ miles and retested. 2 diagnostic codes problem: P0420: B1 catalyst system efficiency below threshold and P0442: evaporative system leak detected (small leak). Still check engine light not showing up when power on. Please help if you can. Thanks in advance.
Discussion Starter #8
Lance, Any advice on the 2 diagnostic codes problem: P0420: B1 catalyst system efficiency below threshold and P0442: evaporative system leak detected (small leak)?
BMWCCA HPDE Instructor
Question: Is the water temp gauge going to exactly 12 o'clock and staying there after about 10 minutes of driving? If not, the t-stat has failed in the open position, thus causing the engine to run rich, which will trip up the 02 sensor and trow a code.
Also, the evap system leak could just be something as simple as a worn out seal on the gas cap.
Discussion Starter #14
Temp gauge gauge is fine. Saw online below efficiency threshold could be a bad cat conv. True or still maybe just an O2 sensor?
1 - 14 of 14 Posts
