That's the power steering not the transmission.Thx guys
On the top of the motor there's a cap that says ATF ONLY ,
I assume that's where I can add fluid? Why else would that be there?
If you have a small leak then you should:2003 325i
137k
So if there's no dip stick his does one check the tranny level?
What if uou have a small leak ?
^^^^^^^^ This!That's the power steering not the transmission.
