1 - 4 of 4 Posts
I need some advice. I have a 2000 540i with 146,000 miles on it. It runs well. It does, however, need new oil pan gaskets, new sway bars and bushings. With labor, I am over $2000 on a car worth $4500.
Questions: Get it fixed and hope to get another 20k miles before buying a used F10 body?
Trade it now on a E60 535i
Seek to understand,^Value
- Typical 150K mile maintenance issues (1) (2) (3) (4) (5) checklists (1) inspections (1) (2) (3) (4) (5) & check/replace all fluids (1) & should I buy a BMW (1)
How to identify & fix an oil filter housing (OFH) leak (1) (2) (3) (4) & how to identify an oil pan gasket leak (1) & how to remove & replace the E39 V8 oil pan gasket (1) (2) or the E39 I6 oil pan gasket (1) & hints how to replace the rigid metalized I6 oil pan gasket without removing the subframe (1) & if you do remove the subframe, how to build your own hoist & engine-support tools (1) & how to fix broken or stripped oil drain pan plug bolt threads (0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18)
- How to do a complete overhaul of your E39 rear suspension (1) (2) (3) (4) or just the rear subframe axle bushings (1) (2) or the rear upper control arm (1) or the rear shocks (1) & springs (1) & cv boots (1) & M5 sway bars (1) (2) with special tools for rear ball joint removal (1) & where to buy a rear ball joint press (1) (2) & what tools to use for the rear alignment (1) & what are the BMW TIS alignment specs & procedures (1) & how to do a reduced negative camber (1) or normal rear wheel alignment (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) & alignment with (1) or without extra weight (1) (2) (3)
- BMW phantom diagrams (1) & nominal prices by part number (1) & EACTuning prices by part number (1) labor rates by zip code (1) (2) (3) where to find a good mechanic (1) (2) joining BMWCCA (1) (2) & finding a reputable BMW indy in your area (1) (2).
so, the ultimate question is: how much to do you enjoy driving it? that will offset most of the money you will put into maintenance and repairs. at least it did in my case.
Discussion Starter · #4 ·
Well, I am hoping the sway bars and bushings restore the handling, to its previous, tight, typical BMW feel. I enjoy it alot, but have also wanted some more HP to match up against newer models. The Valentine 1 gets a daily workout...
1 - 4 of 4 Posts
