1 - 2 of 2 Posts
After reading a few posts to figure out how to change the fuse for the cigarette adapter, I decided to consolidate this knowledge into one thread for ease of use. I did this on a 2007 335i, so your fuse diagram may be different.
The fuse box is located in the glove compartment behind a panel. Twist each side and the panel can be pulled off revealing:
On the back of the panel you remove, there is a the fuse diagram:
Of course there is not a legend for the myriad of images, so which one is the correct one? This (#30) one is the correct one:
Now, just find fuse #30:
and replace it with a 20 Amp (mini) fuse and you are done.
1 - 2 of 2 Posts
