:yikes: :thumb: What did you use?(Product)
Yes, that was my post, I contacted a Meguiars rep (E36M3 who visits this board) and he said that Hot wheels has acid but not nearly as much as competitors..that was enough for me to decide to use it in only extreme cases (such as Lil-E's project). Since my wheels and brakedust is so minor due to once-a-week cleaning, I just use the non-acidic wheel cleaners but still possess the Hot Wheels for the extreme cases. It does work very good, again not quite a spray on-hose off product, but damn near it (requires very little elbow work)scottn2retro said:I was reading another post (I think it was the Eagle A2Z Rocks) and a concern came up about acid (a common trick against brake dust) and apparently Meguiar's does have some acid (but supposedly very little). .
If you're not Auto-X'ing or tracking the car, a polymer will do just fine. Otherwise, if you plan to be 'on those brakes' quite a bit, I'd suggest what Alee suggested, the high temp Wheel Wax.scottn2retro said:On the other thread, Ripsnort and others are suggesting some type of wax or sealer that won't melt from the higher temps. Some suggestions were Meguiar's Polymer Sealer and Bavarian Autosport Wheel Wax.![]()
Read the thread...fjpanna said:What do you use to clean your rims? You did a great job.
