1 - 9 of 9 Posts
OK, I am new to engine work so forgive me if I am making some simple or obvious mistake.
My car: 3/97 540i 116K miles
I looked at James' 2000 540i MAF cleaning DIY but obviously it is different:
http://forums.bimmerforums.com/forum/showthread.php?t=1228236
There aren't 2 T-20 screws on mine so I don't see how to pull the sensor out of the housing as he shows. I am confused how then I should do the cleaning!
My MAF, what screws do I have:
New bare MAF part:
http://treperformance.com/i-2769234-bmw-540-1997-1998-mass-air-flow-sensor.html
The inside looks like this:
Bentley MAF removal procedure:
I can do this easily, and I have CRC MAF cleaner ready. Should I try cleaning by spraying into the housing with the part out, or is that a bad idea and I just need to figure out what screwdriver to use?
Search, Read, THEN Ask
No need to remove the sensor on the M62 (97-98 models). Just spray CRC MAF Cleaner with the red straw through the grating at the senor in the middle. Let dry for at least 5-10 mins before reconnecting or starting engine.
BTW, when replacing defective MAFs most feedback says stick with a BOSCH MAF and stay away from after market ones as more issues arise from aftermarket. Unfortunately, the M62 MAFs are pricey vs the M62TU ones but save yourself the headaches long term and go Bosch.
New bare MAF part:
They use security torx bits. You can fin them at any parts store. Instead of t-20 it is like tx-20.
You can just clean the whole thing with housing and all shouldn't be a problem. I wouldn't even plug in until it sits and dries for 10 mins. And definitely don't start car for a while. Bet to let sit as long as you can to make sure it dries. It is really quick drying stuff though.
Where is the gunk/dirt supposed to go if I don't take it out?
The MAF is a hot film sensor. If you look closely at the sensor you will see what looks like a piece of flat foil. Spray that and let dry. It's like using brake cleaner on brake parts so it evaporates and removes dirt grime as it washes away.
CRC MAF is VOC so it dries fast but still you'll want to wait a good 10 mins before reconnecting.
Constantly Learning
Seek to understand,^Value
I'll cross ref ...
- DIY for replacing (1) (2) (3) & cleaning your mass air flow (MAF) sensor (1) (2) (3) (4) (5) and how 'not' to clean your MAF (1) & buying a replacement MAF cheaper than the BMW MAF (RangeRover MAF) (VW MAF) (Hyundai MAF) & MAF resistance testing (1)
1 - 9 of 9 Posts
