1 - 10 of 10 Posts
so i have been looking all over for clear lenses for my 04 facelift 325ci but have come to no success...:mad: i was wondering if any of you know where i might be able to find some. smoked preforably i am planning on changing the lenses at the same time i do my angel eyes but cannot seem to find them... RJ
Delusions of Grandeur!
Discussion Starter · #3 ·
thanks well it is for the actual turn lens they are inside the head light i will try and get a picture but thanks for the links
Banned
There is no after market solution for the facelifted coupe. The turn signal housings are built into the headlights so you would have to replace the entire setup in order to get the clear corners.
Radar Specialist
or, you can bake the lights open :)
if you remove the orange reflector in the headlight housing, would you have to replace it with something or can you just leave it out?
Radar Specialist
those but the clear reflector inside is orange. is it ok to remove the reflector and not put it back or is there a replacement clear reflector that i can buy and put in?
Coconut Pete's paella!
I tried reassembling my headlights without the reflector just for kicks when I had the headlight open .... it doesn't look very good at all. I think it would rattle pretty bad too.
1 - 10 of 10 Posts
