1 - 3 of 3 Posts
Whenever I turn with a decent rate of speed (usually giving it a fair amount of gas too), I hear a faint clicking coming from the rear suspension. Diff fluid was recently changed, maybe the diff itself? or a drive axle? Anyone had anything happen similar to this?
I just read somewhere that E36's were susceptible to rear-end failure and the symptom was a ticking coming from the rear of the car... let me see if I can find the link to it...
EDIT: I can't find that thread, but if you Google it you'll see it's not an uncommon issue.
Basically, it's the diff clutch pack retaining ring bolts backing out, which is a common problem on the E36.
1 - 3 of 3 Posts
