Climate control question-Answer is not RTFM
813 Views 3 Replies 3 Participants Last post by  alandf
This time of the year-Fall,can you get just fresh air through the vents without running the A/C or the heat. Opening the windows at 75 or 80 is uncomfortable.
1 - 4 of 4 Posts
I guess a suggestion to use the Search function is out too? :rofl:
Seriously, just turn the temp down to 60 with the A/C off and you will get fresh air.
And turn the thumb wheel between the vents so the blue dot is showing.
DUH-Thanks
1 - 4 of 4 Posts
