Changed out the old blower motor and it worked fine but after a couple of hours when I turned the car and the lights off the ac panel remained lit (expect the slider part of it). Then I turned the lights on the ac lighting went off. Disconnected the battery and all the lights worked as it is intended but after turning the key to the ON positions everything got messed up again. Checked the fuses and found out the heater control fuse (7.5A no.27) was burned out, replaced it but nothing has changed. Non of the climate panel functions are working. This thing happened to me once last summer but after some restart it had been fixed, somehow. Weird thing since this is happening the oil pressure light and the indicator arrows on the dash are barely illuminated when the lights are turned off.
'89 535i
'89 535i
