1 - 3 of 3 Posts
Out of the blue my clutch pedal went limp (hate it when that happens:cry:) Anyway, given that there is no tension on the pedal I can only assume the clutch cable broke or detached somehow.
Does anyone have insight on this issue?
livin large
my clutch pedal went limp (hate it when that happens)
uncontrollable limpness does suck, luckly there are ways to fix those problems:rofl:
but most likely its hydrolic. and either the master or slave cylinder went out. but it is better to change both at the same time.
+1 on that e30s dont have a clutch cable its all hydraulic, you might be able to bleed it and get it to pump up again, but your mostlikely going to have to do what downhiller said.
1 - 3 of 3 Posts
