That's a good beotch, get right to it.thaydith said:Thanks - I'm now going to call my dealer and explain to them that I've never abused my clutch.
It goes something like... from a dead stop bring your motor up to about 4,000RPM with first gear (or reverse! heh) selected and the clutch in. Then quickly remove your left foot from the clutch pedal.DrAMG said:What's dumping the clutch? :dunno:
Dude your clutch isn't going to last past 10k if you keep that up! Once in a while is ok, but daily or semi-daily... no no!thaydith said:I dump my clutch all the time, and a few times I was going like 15mph in reverse when I dumped it. The only issue I have with my clutch is the shuddering when the car is not warmed up. I have just under 3,000mi on my car.
I had to replace the fronts thanks to a nail... but my rear tires are at about 2/16" tread depth.thaydith said:I'm kind of exaggerating; I only do it like once every couple weeks. The only thing that I get pissed about is when I am trying to burn out while turning, only one wheel spins. O'h well, have you replaced your tires yet Webguy330i?
You don't have a clutch. You don't need to worry about it.DrAMG said:What's dumping the clutch? :dunno:
Amazingly there's NO hydroplaning!thaydith said:2/16" you're about due.
Wholly fried-clutch batman! :yikes: :yikes:Nick325xiT 5spd said:Interesting thing I found today.
Seriously burning the clutch clears up the shudder. This is NOT something you can do accidentally. The only reason I did it was because I intend to replace the clutch in the near future, anyhow. I do NOT recommend this unless you are prepared to replace your clutch.
At any rate, I revved to the limiter and engaged really slowly in second, so slowly that the car was barely accelerating. I kept this up until WELL past the scent 'o clutch began permeating the cabin. Maybe thirty seconds or so. Engaged normally afterwards... The clutch felt a little loose, but otherwise OK... and NO shudder. I've put about thirty miles on since I did that and it's still gone. (I'd put abotu fifty miles on the car earlier today.) I'll report back tomorrow.
Again, I am NOT recommending this. It is BAD for your clutch!
It would make sense since the clutch plate is very similar to brake pad material. What you did was like slamming on your brakes at highway speeds to clear the pads, but as you know the problem will come back.... It has something to do with the throw out bearing scoring the clutch plate. This score is what causes the shudder.Nick325xiT 5spd said:Interesting thing I found today.
