1 - 5 of 5 Posts
Still here
Hey
How can i check if my clutch is working perfectly and not slipping?
Also, will a standard clutch slip a lot if you give it 3k revs from a standstil and dump the clutch?
Am wondering if my hesitation is clutch related and know very little about them
:dunno:
Assuming you're really dumping it, it should grab. Are you sure it's slipping, or is it the traction control bogging?
Still here
Discussion Starter · #3 ·
Hi, thanks for the reply.
I dont have TC so think it is the clutch
It sounds like it is slipping but only when i pull away (most likely time i guess)
Put the car in 5th gear, put your emergency brake on and try to go forward. If it stalls then yourt clutch is fine. Its should rock a bit, meaning the clutch would catch and if it does then you know your clutch is ok.
E92 07 328xi, 04 F350 6.0, 92 Jetta Carat
what are your rpms like after you shift, does it look like your rpms are higher then normal after you shift and step on the gas??
1 - 5 of 5 Posts
