1 - 2 of 2 Posts
2008 BMW 750Li xdrive
I have a 2008 750li E66 LWB and need help figuring out what I have to repair to fix 2DCF code. I've recently changed the battery and had it programmed, Alternator changed, and IVM module swapped out. Recalls have been done for upgrading software at BMW and they had to reset the CA by doing a battery reset during recall due to it crashing. It stalls and goes into neutral and engine cuts off when idle. I've had it scanned and no other codes show.
Nuclear engineer
02/2012 X5 35d M57Y CPO 121K miles NOKIAN WR G3 30K miles
2DCFNo message from KOMBI, DME receiver, KOMBI transmittern62_tueEngine electronicsView
Fault Information
Fault Code Description
Fault Code Conditions
Fault Time Condition
No message from instrument cluster
Service Plan
CAN Message Monitoring Instrument Pack Alive Check
Fault Impact
battery voltage >10 V
800 ms after Terminal 15
No suspension of bus activity
Warnings
Service Notes
- Measure resistance on bus
  • Check instrument cluster ECU
  • Check ZGM
  • Check K-CAN
  • Check wiring harness
=> Replace ECU as indicated
© 2021 - BMWFaultCodes. https://bmwfault.codes/. https://bmwfault.codes/About
1 - 2 of 2 Posts
