1 - 5 of 5 Posts
Anyone tell me what this diagnostic code means: Code D6121-000000-01-901
We’ve had a spell of very cold weather and I kept getting messages to start the engine to recharge the Battery or to drive farther. I’ve had th dealer check the electrical system for faults, alternator, voltage regulator etc.. They said the battery tested fine as did everything else. All still under the warranty at no charge but I found this code on the the invoice. I’ve read a lot about the need to use one of the CTEK smart chargers in the X-3 if you do a lot of shorter trips and use the heated seats etc. Which we’ve been doing in this -22 Celsius weather.
Sent from my iPad using Bimmerfest mobile app
Nuclear engineer
So, from where did you get ***8220;Code D6121-000000-01-901***8221;? A general purpose search engine (not G00gle) did not find THAT code, but that format comes from Autel Maxicheck. I hope that your dealer is not using some alternative code reader.
Discussion Starter #3
Came from the BMW dealers invoice. I’ll call them today Doug and ask what it is and what they use to scan.
Nuclear engineer
A DTC code does not identify a failed part to change but a symptom that may be caused by any number of failed components or adjustments that may bedifferentiated by execution of a BMW Test Plan© guide through the fault tree. Consider that a component error may be caused by a broken wire a meter away at the ECU.
Autel Maxicheck does not have access to BMW Test Plans©.
Discussion Starter #5
Thanks Doug, I always learn something new from your posts!
1 - 5 of 5 Posts
