Coding Disaster! (Not really...)
3K views 6 replies 7 participants last post by  jgscott987
#1 · (Edited)
So I'm messing around at lunch today with a open blue pen in my hand. I reach over to stretch and draw a long blue line on the moonroof cover. :mad:
Anyone have suggestions on how to clean ink off the fabric? I read somewhere that you can use alchohol to remove the airbag warrnings from the visors. Would that be safe on the roof liner?
Worst case I guess I can get it replaced. I'd say I can live with it but I can't...
FWIW
DLM
#3 ·
Try rubbing alcohol. It should make the ink bleed and then it will start to disappear as you work with it longer. The rubbing alcohol also evaporates before it can leave a wet mark. The wife uses this method on our microfiber couch all the time. Makes it look brand new.
Let us know if it works. Worst case it doesn't and you have to get a new cover :dunno:
Sean
So I'm messing around a lunch today with a open blue pen in my hand. I reach over to streach and draw a long blue line on the moonroof cover. :mad:
Anyone have suggestions on how to clean ink off the fabric? I read somewhere that you can use alchohol to remove the air bag warrnings from the visors. Would that be safe on the roof liner?
FWIW
DLM
#5 ·
I did the same thing with an exacto knife once.... :yikes:
Check with you local car wash, they usually have cleaner similar to the dry cleaners, it lifts the ink out and doesn't make it run.....
#6 ·
I find that 404 Carpet and Upholstery Cleaner will get out any stain.
